configure bgp routerid
configure bgp routerid router-identifier
Description
Changes the router identifier.
Syntax Description
router identifier Specifies a router identifier in the IPv4 address format.
Default
N/A.
Usage Guidelines
BGP must be disabled before changing the router ID.
BGP selects routes based on the following precedence (from highest to lowest):
  • Higher weight
  • Higher local preference
  • Shortest length (shortest AS path)
  • Lowest origin code
  • Lowest MED
  • Route from external peer
  • Lowest cost to Next Hop
  • Lowest router ID
This command applies to the current VR or VRF context.
The following command changes the router ID:
configure bgp routerid 192.1.1.13
To remove the configured bgp routerid, give routerid value as 0.0.0.0 i.e. configure bgp routerid 0.0.0.0.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
